Is there a simple possibility to access the Windows CE Registry using the LabVIEW PDA module?
we use a PDA device running under Windows CE 4.2 .net Pro. For some applications, access to the Windows CE Registry would be helpful. Unfortunately, the VIs to access the Windows Registry are not supported in the LabVIEW PDA module.
Is there a simple possibility to access the Windows CE Registry using the LabVIEW PDA module (Version 8.0)?
Manuel
(3,812 Views)
Hy,
unfortunatelly direct registry access is not implemented in LabVIEW PDA. You may write a wrapper dll.
Working with registry on Pocket PC
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dnppcgen/html/ppc_stry.asp
Virtual Office Systems has provided a free C++ class library to encapsulate basic registry functions.
http://www.voscorp.com/products/developer/winmobile/voregistry/
Peter Griese
NI
(3,790 Views)
Thanks for your response and the links.
Manuel
(3,787 Views)
