Is there a simulated interrogator (for example PXIe-4844) device in ni max?
Hello, I will buy hbm or micron optics interrogator but previously I will have to work on the LabVIEW. Therefore I want to use simulated optical interrogator. PXIe-4844 is an optical interrogator and PXIe-4844 is the product of ni. When I search this product I can't find in ni max. Could you help me with this please?
(1,551 Views)
Hi akaniboz,
Did you read the title of that dialog? It clearly states "Create simulated NI-DAQmx device"!
Did you read the manual of the PXIe-4844? It clearly states "NI-OSI driver"!
Do you notice the difference?
Spoiler
You can only simulate DAQmx devices…
(1,537 Views)
Thanks for your help but I'm beginner for ni products so you shouldn't be rude!!!
(1,474 Views)
