Is there a .sld file for LabView runtime engine when creating Embedded XP image
I'm looking for a .sld file to aid inclusion of LabView runtime engine in my embedded XP image. Has anyone already written one?
(3,278 Views)
unfortunately, National Instruments doesn't have any sld files for embedded OS'es, however, please checkout the links from the Lookout discussion forum, where someone was trying to do something similar.
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RNAME=ViewQuestion&HOID=506500000008000000AD5C0000&ECategory=Lookout
Although there's no definitive resolution to this thread, the person who answered has said he could be contacted.
Hope that helps
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(3,278 Views)
Hi racer81,
Currently National Instruments does not support using Labview on XP embedded, and although you may get an application running some of the features may not function correctly. I understand this will not have helped you, therefore I welcome other developers to post suggestions.
Have you considered using Labview Real-Time or LV-PDA module for windows CE?
Kind Regards
Tristan
(3,278 Views)
