Is there a way to check if a VI is executable?
Hi - I have a problem. Can anyone help?
I have a top-level VI that calls a whole bunch of different VIs via a "Call by reference node" - a sort of plug-in structure. Anyway, occasionally one of those VIs gets into a state where it cannot be run and this causes all kinds of errors. When a VI gets in this state I get an error "The VI is not exectutable".
What I'd like to do is write some Labview code to interrogate all the VIs in a folder and ensure they can be exectuted.  The only way I can find of doing anything like this is to open a reference to each VI in turn and use an invoke method to run each VI. If it won't run, I get an error that I can capture. The problem is, I'd like to do this without having to run each VI.
Is there a way to find out is a VI is executable without actually running it?
Jon.
(2,903 Views)
Accepted by topic author Tournifreak
Yes, open a VI reference to each VI and use a property node to check the Execution state. One of the states is "Bad". If the VI is "good", you'll get an "Idle" state instead.
Easy Peasey, Lemon Squeezie.
(2,898 Views)
Thanks - that's great - I knew there must be a way!
Jon.
(2,890 Views)
