Is there a way to convert raw data into a JPEG picture right away?
I have raw jpg data coming through the serial line.
Can I convert this into a jpg image right away?
Van
(3,031 Views)
yes, there wa s nice VI added in LV 7 that makes this very easy.
convert (parse) your serial read, so that the string is converted into a 2D array of integers. Then call these 3 VIs Draw Unflattened Pixmap >> Picture to Pixmap >> Write JPEG File
Before LV 7, I forget if there is a nice VI to help you (I don't have a pre LV 7 version of LV on this machine, so I can't check...)
(3,031 Views)
Thanks Joel.
Thanks for your help.
I don't have version 7 so
I will try to use your idea.
Van
(3,031 Views)
