Is there a way to dynamically allocate a .dll file?
Ok...guys....I want to make sure I get a piece of fact right before I actually launch into the real question itself:
Say I have a .dll that's located in "c:\", when I select that .dll using a constructor node in a VI, that VI is always going to go "c:\" to find that .dll right?
If that's correct, my first question would be:
"what would labview do if that .dll is not at c:\ "?
Secondly, how can I dynamically tell a constructor node where a .dll is stored?
I need to do this, because my .dll file will be sitting in a different location when it is deployed.
This seems to make Labview search for the .dll, which, I suspect, cause the application to start-up really slow.
Thanks in advance! Smiley Happy
(2,372 Views)
You mention DLL, but refer to constructors, which leads me to believe you're actually talking about .NET assemblies. .NET assemblies may have a .dll extension, but they are not DLLs. Assuming you are talking about .NET assemblies, then please read this: How LabVIEW Locates .NET Assemblies.
(2,367 Views)
