Is there a way to enable horizontal scroll bar and disable word wrap for string indicator in LV 7.1?
Right click on string indicator->Create property node.
Select the following to properties:
* Scrollbar.Visible
* Limit to Single Line?
Felix
(4,085 Views)
Thanks but I think that only activates the verticle scroll bar.
(4,081 Views)
Ok, I don't see any option of a horizontal scrollbar. Do you have any working example with a horizontal scrollbar? If I look at dialog and calssic strings, they not even have the vertical.
If you really need a horizontal scrollbar, look at the tree control. They have the option...
Felix
(4,077 Views)
If I remember right, LabVIEW 7.1 does not have a horizontal scrollbar for text controls/indicators and will always autowrap.
I am sure you could program your way around, but it won't be pretty.
(4,071 Views)
Thanks. I guess I have to bear with it then 😆
(4,056 Views)
