Is there a way to force the cursor into a string control when a vi is called
In a .vi I'm wrighting I need to input a new serail number at the beginning of each run. Is there a way to force the cursor into the string control box every time the start screen returns? eliminating the need for the operator to move the mouse around and click.
I would like to THANK all that have replied to my questions in the past. It has been a big help!
TeBlues
(3,906 Views)
Right click on the control and select Create -> Property.  Right click on the property and select Key Focus.  Right click again and select Change to Write.  Then wire a True constant to the Key Focus property.  When the code is run, the control will have focus, which means the cursor will be in the text box.
- tbob
Inventor of the WORM Global
(3,890 Views)
Create a property node for the string control and set the "KeyFocus" property to True.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(3,887 Views)
There is a property called 'Key Focus' for your string control.  If you set this to TRUE after calling the vi, you will make this string control active.
I guess I was too slow Smiley Happy
Message Edited by rpursley8 on 11-20-2006 11:43 AM
Randall Pursley
(3,885 Views)
ah, problem solved.  what a community.
Message Edited by Space_Flight on 11-20-2006 10:08 AM
(3,878 Views)
