Is there a way to get video acquisition for LabVIEW through the USB port?
Using either the LabVIEW version 7 or lower versions.
(2,674 Views)
jeff au;
You may want to check IVision for LabVIEW:
http://www.geocities.com/irene_he/IVision.html
Regards;
Enrique
www.vartortech.com
(2,674 Views)
Imaq is probably the best solution, but I know of a good ActiveX control that is easy to program with for USB Web Cameras. It can be found at www.fathsoft.com and it is called videocapX. They have really good documentation for programming this control, and the control is fairly cheap.
(2,674 Views)
