Is there a way to have a mirror variable for multiple indicators?
I have a test program that can handle multiple test scenarios and separate their settings by using tabs in my front panel. I have a string indicator showing the status of each step of the test procedure and since I want the operator to always see the status, I have a status indicator on each tab but they always show the same content. This causes to perform write one value to multiple local variables each time I have a new status. Since I am going to optimize my program, I was wondering if there is a way to have a mirror variable (I just made up the name) that represents multiple indicators so my one write to that variable reflects all those indicators in all tabs on my front panel.
Message 1 of 18
(4,163 Views)
Accepted by topic author mohammad_m
Just move the status indicator from being contained in the tab control and simply place it on top of the tab control in front of it. Then you only need a single status indicator.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 18
(4,160 Views)
Thanks for the quick respond. Due to space limitation in my front panel, the status indicators in different tabs are located in different places with different sizes and I don't have a free common space on all tabs to consider it for one out of tab indicator.
Mohammad
Message 3 of 18
(4,154 Views)
The indicator could be res-sized and moved when switching tabs but that would be a bit of a pain.
Provided you do not update the indicator more often than required, you may just was to go with what you have now.
Ben
Message 4 of 18
(4,145 Views)
Right and since the whole goal is to simplify the program, changing the property of indicator makes it more complicated. The program supposed to be small but over time I kept adding new features and now ended up with a monster.
Is there anyway that I can convert my existing indicators to global variables and call them in a function?
Mohammad
Message 5 of 18
(4,143 Views)
 Sure but I do not suggest you do it if the indicator is getting updated very quickly.
Look at these images for inspiration. That is an album of images of what I call a GUI controller that is useful if the GUI is not being hammered hard and you can tolerate the hit to the UI thread.
Ben
Message 6 of 18
(4,132 Views)
I understand your diema but I would contend that the UI design is not very good. UIs should be consistent to the user. If the user has to scan around the display to find the status it is not a very good user experience. The status should be placed in a consistent spot and remain the same size. Usability is as important as correct results.
Mark Yedinak
LabVIEW Champion
Message 7 of 18
(4,128 Views)
Quick is a relative term and I'm not sure what exactly you mean by that. The fastest status refresh rate that I care is 1 sec when I call my timer. Is this too fast for what you are saying?
Mohammad
Message 8 of 18
(4,125 Views)
Mark,
I absolutely agree with you even though I hate to admit it but as I said the program grew little by little and in rush of deadlines. May be you are right and the solution is to rearrange my front panel and use your method but I prefer to go there as the last solution.
Mohammad
Message 9 of 18
(4,119 Views)
Ben,
I'm not sure I understand the images. Are you feeding some references into the functions and modify them by that function? If so that means you are still performing a read for the references to feed them into the function. Could you explain please?
Mohammad
Message 10 of 18
(4,112 Views)
