Is there a way to have an image (simple circle) change color in respect to values in an array?
I have a vi that processes data from 5 different sensors on a sole. I have graphs of the data but for user-friendlyness I would like to have an image that relates sensor placement to data.
In an ideal world I have 5 cicles on an image that change color depending on a certain row of the data, with a scroll bar that goes through all the rows.
Sort of like a boolean led circle but with more than just T/F
Is this possible?
Thanks!
(2,803 Views)
If you can accept a square instead of a circle, you can use a color box indicator.  It's just like a numeric indicator (it's in the numeric palette) but it displays a color instead of a number.
(2,791 Views)
The Silver palatte has a round color box.
If you don't have 2011 or 2012- a search on the forums will yield a custom color box that is round.  (check my posts circa fall 2009) Here
(2,781 Views)
Customizing square color box to round and dimming, it's crazy coool!..credit goes to altenbach
(2,770 Views)
@apok wrote:
Customizing square color box to round and dimming, it's crazy coool!..credit goes to @altenbach
It's even an Idea. 😄
(2,754 Views)
