Hi Matt,
It is an Interesting Problem. Using Control Editor Can be tricky and Frustrating.
Some times I use a trick for many such problems. What I did is this - Created two Gauges with Identical Scales. One is Smaller than the Other in Size. So we have a Large Gauge with Large Needle and a small one with Small Needle.
Now I color My small Gauge - Border, Face and Center Pivot - Transparent. I leave the needle as is.
Third I Put the Smaller Gauge on top of the Larger Gauge. Make Sure the Large Gauge is Moved Backwards and the smaller Gauge (Transparent) is in Front.
Now You actually are Looking at a Gauge With two Sized Needles!! Purists Might say, hey thats not fair. But I had the clock face ready in 5 Minutes Flat!!
Anyway, I am Attachin
g a Small Illustration vi in ver 6.0 for you to see. Oh Yeah!! You need to put some engine under the hood though!!
Good Luck!!
Good Luck!
Mache
