Is there a way to ignore Value Signaling event in event structure?
You can dynamically register\unregister for value change events:
Message 11 of 13
(589 Views)
Yes I have made the mistake of assigning signaling property to indicators in my code. I didn't realise this is a bad practise. Will correct it.
Message 12 of 13
(570 Views)
Accepted by topic author linu95k
That has it's uses.
A value that shouldn't be changed by the user, but should trigger an event can be done that way. Often a SubVI can be used (e.g. don't value (signal) but call the sub VI).
One advantage of an indicator over a control (iff the user should be able to edit) is tabbing is automatically off, and it's clear to everyone the user can't edit.
Message 13 of 13
(557 Views)
