Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Is there a way to include additional data in file header?
Phil_at_Princet
on
Member
10-19-2004
10:28 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Is it possible to include several global variables as part of the file header when writing data with the Write LabView Measurement File VI?
0
Kudos
Message
1
of 3
(2,672 Views)
Reply
Re: Is there a way to include additional data in file header?
johnsold
Knight of NI
10-19-2004
12:38 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You could write your own header using the standard file VIs and then append to that file using Write LabView Measurement File VI.
Sometimes it is easier to look inside the Express VIs and use them as starting points when you want to do something they are not really set up to do.
Lynn
1
Kudo
Message
2
of 3
(2,672 Views)
Reply
Phil_at_Princet
on
Member
Author
10-20-2004
04:42 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Thanks for your answer. What I ended up doing was converting the numbers to text strings, concatenating them, and then placing the string in the comments input of the write data VI.
Phil
0
Kudos
Message
3
of 3
(2,672 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
