Is there a way to interactively select a worksheet from an Excel workbook in Labview?
All of the examples that I can find only allow you to select a sheet by knowing it's index number or the exact name of the sheet.  I haven't been able to query or otherwise find out what sheets are in the workbook to allow the operator select one.
(3,450 Views)
Hi flow,
see this link please and change the "new ..." vi with the "open ..." vi which you will find two posts below them.
http://forums.ni.com/ni/board/message?board.id=BreakPoint&view=by_date_ascending&message.id=5589#M55...
Mike
(3,448 Views)
Thanks!  The bit of information that I needed was to iterate the sheets and get their names.  I have successfully integrated this into my program and am now able to select a particular sheet from an Excel file.  With any luck, I won't need any more help to finish this project.
(3,437 Views)
Hi Mike,
Can you please post the latest available link to the one you had mentioned?
When I tried to open it, it said that it had been deleted. Smiley Surprised
- Partha ( CLD until Oct 2027 🙂 )
(3,344 Views)
Partha,
I tried tracking down the exact thread that Mike was linking, to no avail, but maybe this would help you out just as much:
http://forums.ni.com/ni/board/message?board.id=170&message.id=332297&requireLogin=False
Rob K
Message Edited by Rob_K on 09-15-2008 01:43 PM
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(3,308 Views)
Thanks, Rob.
(3,297 Views)
