Is there a way to make an mpeg or avi movie of my waveform chart
I am using Labview 5.1 and I want to make a movie of my waveform chart of my data. Maybe mpeg or avi. Is there a way to do this?
(3,280 Views)
You could print your chart to different graphic archives and then use a third party program to create a movie, but if you want to create the movie programatically, perhaps LabVIEW paint? toolkit could fix this.
(3,279 Views)
The best way of doing this that I've found is to use a freeware program from www.shareware.com called SnagIt. Snagit will take snapshots of your screen, window, or area of your screen, as well as make an .avi of your screen, window, or area of screen. If you set the area to your graph, you can create an .avi of it. That's the best and quickest method (with no programming).
Mark
(3,279 Views)
trey:
Try Microsoft Camcorder (available in the Office97 Value Pack, and possibly elsewhere) It makes an AVI of anything on your screen.
chutla
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(3,279 Views)
I do not know direct way to do this in LabVIEW I am using also Matlab.
I am collecting just every n-th scan of my plot in an array and then save it as a spreadsheet file. Next I am using Matlab to plot it and save all plots as an avi.
(3,279 Views)
