Is there a way to programmability generate a double click event?
Hi guys, I have an application where some functions are triggered by mouse-double clicks.
If there is something wrong with the function, I want the program to retry it automatically.
Is there another way to do this apart from having to stick a while loop within the double click event?
I am reluctant to do this because I have many other event cases.
It will be great if I can "regenerate" the event, or simply re-execute the event that was just executed.
(2,831 Views)
Hi jack,
             Are you looking for something like Norbert's VI
Thanks as kudos only:)
(2,823 Views)
Here is the thread that discussed about it.
(2,809 Views)
:manhappy:Thanks guys! I will check your suggestions out
(2,785 Views)
