Is there a way to programmatically get text from an existing vi's icon and programmatically enter text into a new vi icon?
(3,532 Views)
You might want to look at the source for the icon editors here.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,530 Views)
Hello Pat,
As far as I am aware, there is no way to easily do this programmatically with property/invoke nodes. You could try calling the VI's icon image using an invoke node and use some type of image manipulation to create the text on the icon, then recreate the image using an invoke node. Please let me know if you have any other questions regarding this issue.
Doug W
(3,475 Views)
there is a little-known Icon API in VI.llb\LabVIEW Icon API. Here is a use example
Used to remove blank banners from a template created project.
The same library puts text in banners for projects when desired
(3,463 Views)
Thank you Jeff, do you know if it gives the icon text as one of the layers?
Thank you
(3,453 Views)
Thank you
If text is in a layer the layer should contain text or text lines. I've never dug deeply only under the expert tutaledge of Darren N. to get one feature out of a project template.  The VI documentation should be top notch thoughSmiley Wink  If not.... you could fix it LOL
(3,437 Views)
