Is there a way to programmatically get the list of SCXI chassis?
Hi all,
I need to get the list of connected SCXI chassis but it seems that it isn't possible (chassis device is not returned by the DAQmx property node DevNames).
Can you help me?
(3,000 Views)
Find hardware will give all the Reference of connected device, Use Propert and Methods and Filter the Needes Hardware Device
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(2,962 Views)
