Is there a way to programmatically press enter or yes to close a dialog box in an external application?
I am using Labview 8.0 and the Run Application and Close Application VIs in the Winevent.llb.  This works fine except that when certain external applications close they pop up a dialog box asking the user to click "Yes", "Cancel" or  "OK".  How can I make Labview click the "Yes" button in this case.  VB has a send keys command, but I never really got that to work for this type of case.  Thanks.
(3,148 Views)
Some applications, excel workbooks for example, have an option to save before closing.  You can either wire that true or false to prevent the popup.
(3,140 Views)
Unfortunately my application was not Excel.  I did however solve the problem:
I Used the Show Window.vi from WINUTIL.llb to get focus on the Application Window, then used the Delay function in LV 8.0 to wait 0.1 sec, then used the simulate_keyboard.vi to send a return. I lost the link to it, but this is the improved? version (http://forums.ni.com/attachments/ni/270/837/1/simulate_keyboard_modified.vi).  Although the dialog box briefly appears and beeps it works good enough for now.
Andy
(3,135 Views)
