Is there a way to remove (or just not show) the box drawn on top of a cluster datatype viewed as icon?
Do I spot a default icon in there 🔍
Former Certified LabVIEW Developer (CLD)
Message 11 of 16
(704 Views)
Yeah.  I spotted that after I posted it.  Usually I edit the icon when I create the VI.  On rare occasions I forget.
Also, for sub VIs that never appear on any block diagram, I'm OK with using default icons; e.g.:
Message 12 of 16
(677 Views)
But isn't the definition of a subVI that it appears in a block diagram?
Edit: Well, come to think of it, a subVI called dynamically will never appear in a BD.
Bill
CLD
(Mid-Level minion.)
Message 13 of 16
(669 Views)
Good point.  But is a VI that's called by proxy (e.g. post-build action) a sub VI?
Also, "SubVI" refers to the object on a BD that calls a VI; whereas "sub VI" refers to the VI that's called.
Message 14 of 16
(648 Views)
Really?  I always just referred to it as "the VI that gets called from the other one".  I never knew there was a term for it.
Bill
CLD
(Mid-Level minion.)
Message 15 of 16
(630 Views)
As I understand the english language, a "sub <anything>" is an <anything> that's beneath some other <anything> (usually the same kind of <anything>).
"SubVI" (exact capitalization and no space) is the class name of the BD object that calls a VI.
Message 16 of 16
(612 Views)
