Is there a way to run a For Loop independently within a While Loop in LabVIEW 2013?
In my program I would like to run a For loop inside of a While loop, and have them run independently, at their own execution rates.  As a test, I wrote a simple VI with a While loop with 1 second timing, and into this I inserted a For loop with 3 second timing.  I created indicators for both iteration terminals.  Upon running the VI, I found the While loop waits for the For loop to run N times before the While loop executes again.  I also found that sometimes the first iteration of the For loop will end at 1 second rather than 3 seconds, and the STOP button to terminate execution of the While loop does not always work.
(3,144 Views)
Accepted by topic author ksinks
That is expected behavior. LabVIEW is s DATAFLOW language. If you want the loops to be independent, there can't be data forcing a dependency so use separate loops.
(3,139 Views)
This is contrary to any programming language loop structure.  Even more so in a data flow language like LabVIEW.  A while loop cannot begin a new iteration until all the code in the loop has executed.  Period no way around it.
You could run the loops in parallel and use a synchronization method to control relative timing.  Have you gone through the "Getting Started exercizes?  They might help you understand what happens in a LabVIEW vi
(3,137 Views)
Thanks, how would you synchronize the loops?  I have gone through the Getting Started exercises and manual.
(3,113 Views)
Why would synchronization matter? Did you want them to run independantly at their own speed or not?
Regardless, there's a synchronization pallette with functions for this, as Occurance.
Other solutions include a common loop counter and a case structure executing every X'th iteration, or having the faster loop send a queue or event every X'th loop that controls the slower loop.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,079 Views)
