Is there a way to save a ".HPGL" file from a network Analyzer to a computer?
Is there a way to save a ".HPGL" file from a network analyzer to a computer?
using LabVIEW and Network Analyzer 8753ES
Message 1 of 9
(3,233 Views)
See the floppy?  (I believe it's called something stupid like "external memory" in the menu.)  Other than that, I think there's an ancient program to grab data from the NA, but I don't remember what it is... Sorry.
Bill
CLD
(Mid-Level minion.)
Message 2 of 9
(3,185 Views)
Sorry I missed being specific. Do it using GPIB connection.
Message 3 of 9
(3,153 Views)
Hi JB,
Read the (programming) manual of your device.
Learn about it remote programming using GPIB connection.
When the device supports such a command: send the command to fetch the HPGL data and save this data to a file…
Message 4 of 9
(3,150 Views)
I have already developed a program to obtain different equipment data, of course using GPIB and LabVIEW connection.
But the problem is getting an identical copy of the analyzer screen using GPIB and LabVIEW connection.
Message 5 of 9
(3,145 Views)
Might be easier to just graph the data.
Bill
CLD
(Mid-Level minion.)
Message 6 of 9
(3,126 Views)
I already did it is very easy. But I need to show the markers ...
Message 7 of 9
(3,122 Views)
Hi JB,
use cursors and annotations in a graph…
Message 8 of 9
(3,100 Views)
Unless the device has a documented GPIB command to create said HPGL file and then to read it from somewhere on the device, no there is no way to do what you want.
A quick glance through the programming manual showed the OUTPPLOT; command which seems to be supposed to return the actual HPGL plot file as a string.
Rolf Kalbermatter  My Blog
Message 9 of 9
(3,085 Views)
