Is there a way to see if a subvi has something connected to a terminal?
If I have a sub vi inside a main program and the terminal is not required. Is there a way to know if something is connected to the terminal?
Tim
GHSP
Message 1 of 15
(4,109 Views)
to test at runtime, you can set the default to some bogus value like 'nan' or -1 or empty string.  If this is still the value in the subvi you can tell if the value is still the default value and most likely not wired.  At edit time, scripting can accomplish this (not for the novice).
What are you trying to do?  The answer might debend on this.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 2 of 15
(4,104 Views)
I am looking to see if something is connected and if nothing is connect I would like to have the program do something totally different than if something is connected.
Tim
GHSP
Message 3 of 15
(4,098 Views)
How would you acvcomplish this with scripting?
Tim
GHSP
Message 4 of 15
(4,094 Views)
I would probably handle it with the first method, check to see if a valid input is recieved.  You can also try making a polymorphic vi.  This is not a runtime decision branch on the code logic, wiring is done at edit time.
Paul Falkenstein
Message 5 of 15
(4,092 Views)
Accepted by topic author aeastet
This is very quick and very dirty, but just to give you an idea.
Message 6 of 15
(4,084 Views)
Nice a little cleaner than my solution subvi->terms->Wire->arraysize(terms[])>0
Paul Falkenstein
Message 7 of 15
(4,075 Views)
would be nice if the terminal had an iswired? properity so you did not have to look wt the wires attached to the terminals.
Paul Falkenstein
Message 8 of 15
(4,070 Views)
You mean like this?
___________________
Try to take over the world!
Message 9 of 15
(4,031 Views)
Darin.K
Where did you get these properties from. I do not see them in my version of LabVIEW?
Tim
GHSP
Message 10 of 15
(4,015 Views)
