Is there a way to tell LV to ignore the .git folder when searching for missing vi's?
I'm just starting to explore source control with Source Tree, which has placed its usual .git folders in all my project folders. Now, when LabVIEW is loading a vi and is looking for missing subvi's in the project's folders, it wastes time searching in the .git folder. Is there a way to tell LabVIEW to ignore the .git folder?
(843 Views)
Based on LabVIEW roadmap, R&D is working on Git integration with LabVIEW and I believe part of that will be improvements to context aware of the .git files.
Santhosh
Soliton Technologies
(830 Views)
Accepted by topic author FlatCat
Hi FlatCat,
This is probably because your .git folder is at the same level as your VIs.
Try putting your sources in a subfolder, similar to this:
From NI documentation:
By default, LabVIEW will look through the following locations in order (\* means LabVIEW will search through the subdirectories):
  • <topvi>\* - the location of the top level VI
  • <foundvi> - the location of the last VI found
  • <vilib>\* - the LabVIEW vi.lib
  • <userlib>\* - user.lib
  • <instrlib>\* - instr.lib
Raphaël.
(813 Views)
When cross-posting from reddit, make sure to include a link to the original discussion to avoid duplicate efforts.
(782 Views)
Same answer as what Raphaël gave in this thread: https://forums.ni.com/t5/LabVIEW/Is-there-a-way-to-tell-LV-to-ignore-the-git-folder-when/td-p/442686...
Rolf Kalbermatter  My Blog
(746 Views)
