Is there a way to undo the Ctrl+click+drag BD expansion after the fact?
I had an internet help make some simple code additions for me and in the process expanded my BD to a degree that it is very bothersome to work on.  She left me with a large gap in the center of my code, then saved it.  Is there a method that does the opposite of Ctrl+right click+drag?
I basically need to move half of a state machine loop(s) and all included VIs on that half of the BD at once?  Don't want to manually move 20+ cases worth of VIs individually if I can help it.
Now the real question - Why does an intern have a bigger screen than I do?!?!?
Message 1 of 10
(4,320 Views)
roll back to a previous version in source control? Cat Wink
Once it's saved you're pretty much SOL.
See if the block diagram cleanup makes things manageable. :dunno
Message 2 of 10
(4,319 Views)
If you're lucky the code cleanup tool (ctrl+u) can help.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 10
(4,304 Views)
Block diagram clean up doesn't work, it actually makes things worse.  Too much done already to revert back a version.
If nobody else has any ideas, I'll just deal with it in the mean time and make her fix it later.
Message 5 of 10
(4,296 Views)
@AMP12 wrote:
[...]  and make her fix it later.
And take away her large monitor.  When I was an intern we didn't have large monitors, we programmed using...  Ah, forget it; you kids wouldn't understand.
Jim
Message 6 of 10
(4,274 Views)
I'd be tempted to take the intern's large monitor away and then ask them to correct the problem.  I think I've got an old EGA monitor around here somewhere.  Smiley Very Happy
Message 7 of 10
(4,271 Views)
An Etch-A-Sketch? Smiley Wink
Message 8 of 10
(4,266 Views)
Jim
Message 9 of 10
(4,246 Views)
ctrl+u  can be tuned in the LabVIEW ini to provide better results.  I have not found a magical setting for it yet.  (My BDs don't usually get too bad)  but I think a reasonable BD Clean-up is achievable with some persistance (try it- undo -reset- try it again)  Take snapshots along the way.  Perhaps even try 1 setting Optomized vertically and reset to optomized Horizontally and clean again.  (That technique seams to hold the most promise IMHO.)
Now, What were you doing giving a chunk of code to an intern WITHOUT a style guide requirement and supervision?
see post 17 here  You are not aloneSmiley Wink
Message 10 of 10
(4,205 Views)
