Is there a way to use a text file or spreadsheet instead of the GUI to initialize variables in LabVIEW
I am new to LabVIEW and have a question. Is there a way to completely skip the GUI altogether and just drive a LabVIEW program with a "settings" file/spreadsheet that initializes variables and such?
Thanks in advance!
(3,415 Views)
Of course.   Search the forum or LabVIEW example finder for how to read either a text file or an Excel file.
Then you can use that data in your program.
(3,390 Views)
Accepted by topic author stdel
Did you notice the File I/O Palette on the Block Diagram?  In addition to text, "Delimited Spreadsheet" (.csv Text files), and otherwise-unformatted Text files, you can also find (on this Palette) functions to read/write XML files and Configuration (a.k.a. ".ini") files.  Finally, if you have the Report Generation Toolkit installed, you can read/write Excel (meaning .xlsx) files, but this shows up on a different ("Report Generation") Palette.
Bob Schor
(3,365 Views)
You can also use JSON files if you are familiar with those.  check out "JKI JSON" or "JSONText" on the VI Package Manager.
(3,341 Views)
There is also a full set of database connectivity tools
So to recap...
1) ini file
2) xml
3) json
4) csv
5) xls
6) database
Shall I go on?
Former Certified LabVIEW Developer (CLD)
(3,339 Views)
Got it! Thanks everyone for the replies!
(3,313 Views)
