Is there a way to use usb 6009 a/d as a Voltage controlled oscillator
Hello all out there:
I am inquiry if any developers/programmers know how to convert the USB-6009 A/D device into a voltage controlled oscillator. I would like to measure voltage from my device and output that to as a frequency sound signal with a base programmed tone in one speaker (left) and the VCO generated tone in the other speaker (right).  I have made a VI that plays 2 tones but the tones are generated one right after the other not simultaneously. Any insights would be greatly appreciated.
(2,987 Views)
Check out this thread.
(2,959 Views)
First of all do not use Express VIs. They only cause you trouble. I suggest you go to help in the toolbar, then select find examples. Search for sound. I think the generate sound example is a good starter for you. Your project is doable. But do not write data more often 5 pr second to the sound output write.vi
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,934 Views)
