Is there a way to write data to xml that can give me the following format - I can not get it with = signs etc
<?xml version="1.0" encoding="utf-8" ?>
<Machine  CreatedDate="06/09/2010" MachineSN="AAAA3" HEADTYPE="green" HEADSN="Head1"  LENS="LEN1" TEST="TEST1" TESTERS="10134194">
  <Amp Value="18">
    <TempTest Value="Head1">39</TempTest>
  </Amp>
  <Amp Value="20">
    <TempTest Value="Head1">132</TempTest>
  </Amp>
  <Amp Value="22">
    <TempTest Value="Head1">43</TempTest>
  </Amp>
</Machine>
(3,175 Views)
Those are called XML-attributes, I don't know about the native LabVIEW interface, but the JKI-easy XML toolkit has the ability to read and write those attributes.
Ton
My LabVIEW Ideas
(3,161 Views)
You can also do this with the XML functions. See the example I posted in this thread: http://forums.ni.com/t5/LabVIEW/XML-Attribute/m-p/791538
(3,147 Views)
hi,
Thank you for your help, I seemed to miss the attributes!!! It should satisfy my needs I will try it out
Thanks once again
(3,124 Views)
I have another question that I have not managed to do - How can I convert a bundle (graph) to XML? Is it possible to put an XML element in a for loop - will it add a new child every time? I think that I could do that if it is possible instead of converting a bundle to XML?
(3,116 Views)
If you are using the XML Parser VIs then you need to create your own schema and you need to use the XML Parser functions to create the necessary nodes. If you use the Flatten to XML functions then these use the LabVIEW schema, and the cluster is automatically converted to XML.
As for your question regarding children, you can create the nodes any way you want. Yes, you can use a loop to create multiple children for a node. Please refer to the documentation on the XML Parser VIs if you are using them. There are also examples that ship with LabVIEW.
(3,109 Views)
The flatten to XML is not good enough for my needs, I will take your advise and learn more about the parsers, thank you for the help
(3,105 Views)
