Is there an easier way to make an integrator for a real-time signal?
I'm making a VI to calculate lung tidal volume, which is the integral of the difference between two flow sensors over time. I expected to find a function that would integrate some real-time signal coming in one data point at a time (using some internal state to remember the value it had) but so far haven't found anything like that. I wrote the below VI to do this manually using shift registers and a simple trapezoidal integration of the new signal based on the known rate of the loop.
This solution seems to work but I feel it's maybe over complicated, and it seems like there probably exists a pre-made function that uses the system time and an internal state to do this all without so many moving parts,and probably more accurately. I haven't been able to find anything so far by searching for it, but I am pretty new to Labview and might just be misreading or misusing some function.
Any help finding a better function, or any ideas on potential problems with this solution, would be appreciated.
(2,814 Views)
Hi Tarnarmour,
To me this VI looks like being simplified too much because it's empty…
Mind to attach your real VI?
(2,756 Views)
Accepted by topic author Tarnarmour
NI_PtbyPt.lvlib:Integral x(t) PtByPt.vi
From the code inside, I think it might use trapezoidal integration.
(2,748 Views)
Well I'm not sure how that happened, I'll be trying to check this one more carefully after I post.
(2,731 Views)
I can't open your VI because I haven't (yet) installed LabVIEW 2020.  But note Wiebe's reply -- the Point-by-Point functions can be found on the Signal Processing Palette.
Bob Schor
(2,711 Views)
Thanks! I've been looking at it and I think it'll massively clean up a pretty horribly messy VI 🙂
(2,674 Views)
