Is there an easy way to change 323 (string) to "43 01" (hex string) or 3249 (string) to "B1 0C" (hex string)?
Thank you.
(2,543 Views)
Accepted by topic author chuck72352
Like this?
It kind of depends on exactly what you want in the end.  Do you want a string that shows 4 characters that are the hex number for the number you input.  Or do you want a string that is only 2 characters (1 for each byte), but the indicator is formatted to show those in hex display?
Message Edited by Ravens Fan on 04-09-2010 12:30 PM
(2,527 Views)
I'm trying to get a string that shows four characters that are hex numbers for the input.
Thank you for your solution.
(2,519 Views)
