Is there an example vi for converting an array of boolean to list an array of Int based on a selected T/F state?
I would like to use arrays to minimize code.
I am trying to generate an array of int base on an array of boolean randomly selected.
(2,686 Views)
You can try using 'Boolean to 0,1.vi', found in the Boolean palette: this vi converts a scalar, array or cluster of booleans to a scalar, array or cluster of word (I16 integers).
To use it, simply wire an array of booleans (indicator) to its left, and an array of integers (control) to its right et voilà.
Roberto
(2,686 Views)
