Is there an inherent limit to the length of a listbox in LabVIEW 2010?
Is there an inherent limit to the length (number of lines) of a listbox in LabVIEW 2010?
Thanks.
(3,218 Views)
Accepted by topic author rickford66
Probably limited to 2^32 entries.
But I bet the UI becomes unmanageable long before that.  I experimented with putting 1 million entries in.  It worked, but my mouse clicks seemed to get slow.
(3,213 Views)
Ok, thanks.
(3,211 Views)
I came to the 2^32 number because the underlying item list data in a listbox is a string array.  Array functions are geared towards using a U32 or I32 number to be able to index out the elements.
Actually, I'd argue the limit is 2^31 because the datatype of the list box is an I32.  So any number greater than 2^31 would exceed the limits for the listbox datatype.
(3,196 Views)
2^31-1Smiley Wink Bit 31 is the sign bit
(3,191 Views)
2^31
Index value is 0 to 2^31-1.   A total of 2^31 items since counting starts at zero. Smiley WinkSmiley Wink  And yes, the 32nd bit (#31 if you count the LSb as being bit #0) is the sign bit.
(3,179 Views)
@RavensFan wrote:
2^31
D'Oh
(3,164 Views)
