Is there an "official" way for a LabVIEW subclass to read its own name?
The issue is that the application uses a database to store its configuration so at some point in the hierarchy, the subclass name needs to stop being a value used for dynamic dispatch and start being used at a parameter for a database query.
I have done a bit of poking and have come up with a hack potential solution that seems to work, but which has "brittle" written all over it. I could also put a value in the class data that says which subclass it really is, but that is ugly. So is there official way of doing this?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,978 Views)
Accepted by topic author mikeporter
Is this:
http://zone.ni.com/reference/en-XX/help/371361K-01/glang/get_lv_class_name/
what you're looking for?
If not, I may not be understanding the question.
(2,950 Views)
You understood fine, that is exactly what I was looking for.
Thanks, Mike...
LabVIEW Champion
(2,942 Views)
