Is there any Example for N9010A EXA Signal Analyzer
Hi All,
Is there any example for N9010A EXA signal analyzer , I tried to use example of MXA got from the driver page but couldnt get to work. I need to capture the RF data form the analyzer. Please let me know if there any example or way to do it.
(3,630 Views)
@AnkitG wrote:
Hi All,
That is an Agilent instrument. Shouldn't be looking for examples on THEIR website?????
(3,626 Views)
As far as I know, the instruments have a common progamming interface (the SCPI commands) so an example should work for all. Just saying that an example does not work is not enough information. You need to provide the name of the example, the parameters, error code that you get, etc.
(3,616 Views)
Nevermind, I got that working now  do need to change few settings while using it for different analyzer ,which were not mentioned  in the readme text file.
thanks a lot.
(3,613 Views)
Can you mention what you had to change for the EXA?
(3,587 Views)
I do need to change the reference level offset ,start and stop frequency, and auto sweep time to true.
(3,578 Views)
