Oops. I guess my question was awfully open-ended wasn't it?
OK, here's the deal.
The VI I created is simply trying to toggle outputs on a digital I/O card. Nothing complicated.
On the WinNT machine, I can toggle the outputs. When I set them high, I see a high voltage from the card. It remains high until I switch it low, when the voltage drops. This is good.
On the Win98 machine, I attempt to toggle the output high, and I hear the click of a relay, and a short current spike, but the voltage does not remain high. When I switch back to low I get no response back at all. The voltage remains low the entire time, with a small impulse jump when I try to set it high.
We assume that the card is switching high, then immediately switching low ag
ain, not holding the high state.
The card on the Win98 machine, however, DOES work with the software included with the card, so we know it can toggle it's outputs.
The Win98 and WinNT machines are nearly identical in their components, with the exception of their OS.
The card I'm attempting to use is a Quatech PXB-32IO/PCI I/O card.
Hope this clears it up a little!
Thanks for the help,
Dave Neumann
d.neumann@astronautics.com
