Is there any function in LV 7.1 which renames directories ?
(3,029 Views)
In LabVIEW 7 there is, I'm sure you can find it in version 7.1
function name "Move" see attatchment
Ayman Mohammad Metwally
Automation Engineer
Egypt - Cairo
(3,028 Views)
Thank you for your quick answer.
But I tried this already and then the files and subdirectories of the directory will be copied to the new directory and then deleted in the old directory. This could take a long time.
If I rename a directory with the windows explorer it takes just a moment. Therefore I search for a function in LV which behaves like this.
Thomas Walther
Software Engineer
Germany - Waldbronn
(3,021 Views)
In the communication pallete you have the System Exec VI, which allows you to run shell commands. You can use it to run the DOS "ren" or "rename" command, but I'm not sure how it will react to DOS commands. Try reading its documentation and see if this helps.
___________________
Try to take over the world!
(3,016 Views)
If you do a search on this forum for "rename directory" you will find a discussion of renaming directories, with an example (the last respondent) that worked when I just tried it with LabVIEW 7.1.1 on WindowsXP Pro sp 2. It uses a dll call, so it isn't a "native LabVIEW" function, but it appears to work in my limited trials.
Putnam Monroe
Putnam
Certified LabVIEW Developer
LabVIEW Champion
(3,005 Views)
OK, thanks a lot for the help in this discussion.
The last suggestion using the "rename" function of the "msvcrt.dll" works fine.
Another way I found was to use the "Scripting.FileSystemObject" of the "Windows Script Host Object Model" in the type library.
There is a function called "MoveFolder" which does the same.
All the best for you all
Thomas Walther
(2,999 Views)
