Is there any tools can check for existed database ?
hi all, is there any tools that can check for that existed database after inserted a database to Ms access??
(2,812 Views)
Open Database Connection will give an error if there's nothing to open, thus it'd work.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,806 Views)
if i want to check any data in the table is it oso the same tool ??
(2,800 Views)
Then you'll open a connection and then do a Select from table to retrieve information. (and close afterwards)
/Y
Qestit Systems
(2,795 Views)
alright i got it... Thanks alot 😄
(2,773 Views)
errr i got one last question...
Is it possible if there is no data in the table goes to the INSERT tool.. if there is data in the table goes to UPDATE tool ??? From the SELET tool..
(2,764 Views)
Still haven't done those SQL tutorials, huh?
Read the documentation on those commands. What do they do? That will answer your question.
(2,756 Views)
