Is there any way of transferring the following Traditional DAQ code to DAQmx?
Hello!
This is an example with two concurrent loops reading from the same buffer. How do I do it in DAQmx?
Is this even possible?
Roger Isaksson, Damill AB
(2,544 Views)
Hello!
I believe this one is under control as well, the program you sent us seems to do exactly what you asked for.
Jimmie A.
Applications Engineer, National Instruments
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(2,514 Views)
Here is the thread with the example code:
http://forums.ni.com/ni/board/message?board.id=280&message.id=1272
(2,508 Views)
