Is there any way to convert .m file to labVIEW FPGA targets?
Hi, I'm new to labVIEW. I'm now doing a project using NI cRIO-9075. I have a .m file for the controller and now want to intergrate it to FPGA module. Is there any converting tools to do that?
Thanks!
(2,885 Views)
Hi Ijiang,
<humor>".m"-files are just text, so you can convert them to an array of U8 to integrate it in the FPGA 😄 </humor>
MathScript isn't supported on FPGA. You have to "convert" (better: re-program) it on your own...
(special humor-tag to clearly indicate a joke...)
(2,864 Views)
I appreciate your reply:)
What about Simulink Models? Can I do convert them to FPGA except re-programming?
(2,860 Views)
dunno 'bout Simulink...
Do you have a Simulink compiler that creates IP for the FPGA in your cRIO in a way/format you can incorporate in your LabVIEW project using the CLIP node?
(2,855 Views)
These models are not directly supported on LabVIEW FPGA. However, if you can find other tools which can take these models and generate VHDL, Verilog, or a netlist for the component you can integrate that core into LabVIEW FPGA using IPIN or CLIP.
(2,843 Views)
