Is there any way to create an installer for Mac OS and Linux OS once a stand alone application is created?
Is there any way to create an installer for Mac OS and Linux OS once a stand alone application is created?  I have created an executable application that I want to distribute to Mac and Linux users (different applications were created in the respective OS).  I was wondering if there is any way to create an installer?  I think there probably isn't...  If the user were to simply download the Labview Run-time Engine from ni.com would they be able to run the application or is it more complicated than that?
Thanks so much for your time.
(4,128 Views)
As far as I know it is not possible to create an installer out of LabVIEW for Mac OS or Linux. It's only possible to create Windows installers on a Windows machine.
So you have to build the application and install the Run-Time Engine. Then it should be possible to run the application. But if other things, like a driver is needed it must also be installed.
(4,111 Views)
On Mac there is an installer builder utility on the install CD but it's not installed by default.
It's called "Package Manager" I think.  It's not bad, but I thinkk it'd be great if this was available from within LV itself.
Shane.
(4,093 Views)
Thanks for the help - I tried doing a custom install but I didn't see Package Manager as an option.  Do you happen to remember where I can find it?
(4,076 Views)
Like I said it's on the Mac OS X install DVD.
Shane.
(4,064 Views)
HI,
I know this post is already a bit older but I am searching for a possible way to build an installer on Mac as well. I searched for that application on the CD, but I could not find it. Maybe it is not included in LV 2010 any more? Does somebody know?
(3,772 Views)
I think Shane tried to say, that it is on the Mac OS X installation DVD, NOT the LabVIEW for Mac OS X installation medium. And that could very well have changed in recent Mac OS X versions as well. They used to have Xcode on it too, but that seems gone as well.
Rolf Kalbermatter  My Blog
(3,754 Views)
