Is there option to not display the increment/decrement buttons by default when changing a numeric indicator to a control?
Is it possible to not have LabVIEW display the increment/decrement buttons when a numeric indicator is changed to a control?
(3,039 Views)
I don't think so.  As far as I know there is no option in tools->options, and I couldn't find anything about that for an .ini file.  Someone more knowledgable might be able to find it, but I'm leaning towards no.
Message Edited by Novatron on 06-13-2006 02:17 PM
(3,045 Views)
I often provide systems that uses clusters to display (indicate) data and then copy them to controls for user input in other parts of the program.  The automatic display of the increment buttons is simply a nuisance.  Thanks...
(3,036 Views)
If I understand you correctly, the attached image might help.
Though I cannot (not to say someone else couldn't) think of a way to do it by default, you can do it programmatically. Your further explanation led me to the image attached. If I haven't gotten it, post a more detailed version of what you're going for.
Hope this helps!
Message Edited by Novatron on 06-13-2006 03:17 PM
(3,034 Views)
You can use the paint brush tool to change the increment/decrement part of the numeric control to Transparent...
(3,020 Views)
Right click on the control and select Visible Items>Increment/Decrement.
(3,012 Views)
