Is there some approach for executing many sql (at least 2 sql) once?
As follows:
start transaction;
sql1;
sql2;
commit;
LV hava many vi for executing sql,but it occur problem when they deal with many sql once. Is there some approach for executing many sql once?
Message 1 of 20
(5,045 Views)
Hi wxjshr,
what do you mean? Do you want to write to two databases at the same time? Can you explain please?
Mike
Message 2 of 20
(5,038 Views)
As follows sql:
start transaction;
update table_1 set money=money-50;
update table_2 set money=money+50;
commit;
I want the sql block execute one time,Labsql can do that?
Message 3 of 20
(5,028 Views)
Hi,Mike
labsql executes only one sql at one time,am I right?
Now I want labsql executes a sql block at one time .How can I do that?
Thanks!
Message 4 of 20
(5,027 Views)
Hi 威海的风,
can you upload your vi? I'm don't understand what you try to do and why.
Mike
Message 5 of 20
(5,025 Views)
11.jpgI just want to execute two sql at one time.Is there a VI can do that?
Message 6 of 20
(5,021 Views)
Hi 威海的风,
what about using a loop? Is it a solution for you?
Mike
Message 7 of 20
(5,003 Views)
Thanks , Mike!
Is there no method do that?
Message 8 of 20
(4,999 Views)
Hi 威海的风,
sorry, i can't tell you if such a funtion exists. Can you explain why you need it? I'm very interested in what you try to do.
Mike
Message 9 of 20
(4,996 Views)
I'm confused. You're already creating a command string that contains multiple SQL statements. What is the problem? What database are you using, and which driver are you using? I know that certain databases and/or drivers (e.g., MS Access and Jet) do not allow the execution of multiple SQL statements.
Message 10 of 20
(4,992 Views)
