Is there someone who is expert in xnet?
I'm having some problem with xnet communication.
my code looks perfect to me. and by my thought it should work properly.
However when I check with xnet bus monitor. Xnet write and read is not working at all.
Can somebody tell me what is the problem?
(348 Views)
your code continuously create and dispose the XNET connection. 2 XNET sessions are created every 100 ms.
Move the XNET session initialization VIs and the clear vis outside the loop. Just keep the 2 VIs read and write inside the loop.
The image below shows an example. Please note that it's just an example. It isn't a fixed version of your code.
(315 Views)
