Is there time stamp with daqmx read
Hi all,
Simple question.  I currently not creating a task or starting a task, I am simply creating a channel and reading that chanel.
Question is...  Why i do not get a time stamp when doing this and must i create a task to get one from this?
-Matt
(2,639 Views)
Accepted by topic author Wolleee
There is a timestamp when using the DAQ Assistant or when you choose to return a waveform data type with the DAQmx Read.
You can't do a read without a task. You do not have to create the task in MAX, though.
(2,635 Views)
