Is this possible: Visualize mesh of a Part + contour?
Use "NaN" in the Z-matrix for any point you do not want to plot.
If you posted an example of what you have so far, this would be more fun (for us) to help you.
How about a screen shot of your graph?
I am sure what you are looking at is much more interesting that the boring screen shots I posted.
"Throw us a bone!" Smiley Wink
Ben
Message 11 of 22
(1,709 Views)
sure. thanks for the reply. Unfortunately entering NaN also disables the contour on that grid, what doesn't look so nice..
I'll attach you some part of the code and the plot... labview doesn't have a zoom fuction for the code, does it?
Message 12 of 22
(1,703 Views)
Cool!
How about making the contour one plot and the grid another?
Message 13 of 22
(1,697 Views)
I'm sorry, I have another stupid question:
If I displace one row, the last point does not show up any more. I could see the missing point, when I drag the plot though, but why doesn't it show up like a regular point?
The idea using two separate plots is a good one, but I will have to see how it will work out in the end - there is still a lot to do and to figure out.
Message 14 of 22
(1,689 Views)
It could be a bug.
Now if you had posted the code (hint, hint) an AE from NI may be able to comment.
Ben
Message 15 of 22
(1,667 Views)
the code for the mesh is actually the same one as in the last example, which is the same that you used in your example. or do you want the vi for that, I use? I just changed the coordinates of one row, so that they are displaced by 1 on the x axys.
Message Edited by sthu on 10-25-2007 08:59 AM
Message 16 of 22
(1,665 Views)
another two concerns:
When I change the view I often end up having some parts of the surface not drawn. Is this a known issue, or do I just have a parameter set wrong?
Is it possible to draw a surface like a triangle?
So far the surface is defined by a 2 dimensional array for every point. I've been able to create a triangle (using the same code) when I set the all the coordinates of the first row to the same coordinate and split the second row up on two coordinates etc.. As this is hard to automize for reading coordinates out of a file, is there an easier way?
Message Edited by sthu on 10-25-2007 09:25 AM
Message 17 of 22
(1,653 Views)
Hey guys,
I've been using the code posted above and it worked pretty well so far. Lately I ran into the situation where I had to visualize a beam. This means I have just a few points, which are in a line. In this case the code doesn't work. I always end up with a line which is the same color all way long. Is there an easy workaround?
Message 18 of 22
(1,567 Views)
Sthu,
Not seeing the green lines in the VI above is a bug for LabVIEW 8.5. It looks like changing the view will make everything visible. In regards to the most recent post (the beam), could you post the VI that created it? I don’t know what I should expect to see.
Charlie M. CLD
Message 19 of 22
(1,527 Views)
This was reported to R&D (#4FT9QOB7) for further investigation.
Charlie M. CLD
Message 20 of 22
(1,497 Views)
