Issue about output of "To upper case"
If the input of "to upper case" is "\C0\00a", then the output will be "?Aa"
Message 1 of 20
(4,133 Views)
The easiest way to answer that question is to just try it out yourself.Smiley Wink
And the answer is no.  It will be \C0\00A  since there is no "upper case" version of the characters C0 and 00 hex.
Message 2 of 20
(4,122 Views)
I am not sure what to make of your post. Is is a question, a comment, or a bug report???
If your string controls/indicators are set to \-codes and you are getting "?Aa", something is wrong. What is your LabVIEW version? Can you attach an example that shows the problem?
The normal and expected behavior is as follows, and that's what I see using LabVIEW.
Assuming that your "\C0\00a" string is actually in \-codes display, we have 3 characters:
  1. \C0 is already uppercase, so it won't do anything to it
  2. \00 is not a printable character, so it won't change
  3. a will chage to uppercase A
Conversely, a "to lower case" would turn your string into "\E0\00a" (in \-code display)
Message 3 of 20
(4,105 Views)
It is a bug report.
And \C0\00a" is a '\' code dispaly, also "?Aa".
 I have tested it on labview 7.1
My Vi is attached
Message 4 of 20
(4,090 Views)
It is a bug report.
My Vi is attached
Message 5 of 20
(4,088 Views)
Thanks for the clarification. I no longer have access to 7.1 to test this, but e.g. in 8.2 everything works just fine.
'Seems it got fixed in newer versions.
Message Edited by altenbach on 10-27-2007 11:27 PM
Message 6 of 20
(4,086 Views)
I still have 6.1. Worked fine at that time.
Chilly Charly    (aka CC)
Message 7 of 20
(4,080 Views)
My output:
...Confused...
Message 8 of 20
(4,073 Views)
Sorry hrongfu
I have tested your vi with LabVIEW 7.1. No bug !!!
No idea about what's wrong with your computer. Something corrupted in your setup ?
Message 9 of 20
(4,048 Views)
This is the difference
陈树学
QQ:276509891 .
EMAIL:CSXCS_366@126.COM
qq群:78561268 80754347 37591940
http://labview.weebly.com/
新书《LabVIEW实用工具详解》已经发售,敬请关注。
Message 10 of 20
(4,047 Views)
