Issue in moving 32 bit Labview project from 64 bit machine to 32 bit machine
Hi ,
I am trying the copy Labview(32 bit) source code from 64 bit machine(windows 😎 to 32 bit machine(windows).
When i opened the project in new 32 bit machine few of the vi.lib files are not recognized and they are all listed in the dependency list. Can anyone let me know what could be the issue.
For example , the below is not recognized by the project.
C:\Program Files (x86)\National Instruments\LabVIEW 2017\vi.lib\addons\database
Attached is the reference.
Anand
Message 1 of 9
(3,204 Views)
Hi Anand,
seems you are missing several toolkits on your new computer, like ReportGeneration and Database…
You need to install them with LabVIEW.
Message 2 of 9
(3,197 Views)
HI GerdW,
The database and Report generation tools kits are already installed. But it is not recognizing it.
Anand
Message 3 of 9
(3,194 Views)
Hi Anand,
are the missing VIs located in the expected place?
Message 4 of 9
(3,173 Views)
Hi GerdW,
Complete .lvlib file is there in the expected place.
C:\Program Files\National Instruments\LabVIEW 2017\vi.lib\addons\database\NI_Database_API.lvlib
Anand
Message 5 of 9
(3,168 Views)
Hi Anand,
the lvlib file is just a XML description: are the VIs also in place?
Your project is expecting them in a certain location: are those locations the very same as expected?
Well, even a "Beep.vi" is missing: are you using a default LabVIEW installation at all?
Message 6 of 9
(3,165 Views)
Hi GerdW,
I am using default LabVIEW installation path only and also to remodify the subject.
The issue not only when opening in 32 bit machine , but occurs when we open the same project in another 64 bit machine also.
And also when i opening the project ,it always shows "One or more dependencies of have changed since the project was last saved " and  "Resolve Load conflict". Do you have any idea to resolve this issue. Some of the vi are always shows to old project path. Is it some where the project path hardcoded for the VIs.
Anand
Message 7 of 9
(3,158 Views)
Hi Anand,
May happen when you move from one computer to a different one, don't worry…
Right-click the item and "resolve conflicts"…
The toolkits might not be available for LV-64bit…
Message 8 of 9
(3,151 Views)
Could it be something to do with the fact that a 32 bit machine will have LV 32-bit installed into "Program Files" while on  64-bit machine it will be installed into "Program Files (x86)?
Bill
CLD
(Mid-Level minion.)
Message 9 of 9
(3,143 Views)
