Issue reading a binary file.
@Bob_Schor wrote:
  Note the use of the "And Array" functions to return a single Boolean if the Arrays are the same.
Bob Schor
You can delete the for loop after the equal node. 'And Array Elements' will work on a 2D-Array and return a single boolean.
Message 11 of 14
(2,503 Views)
Or just right-click on the Equals and choose the comparison type to "Aggregates".
Also, I tend to use "Create or Replace" for the Open/Create/Replace File option.  If the file already exists and you have it to just "Create", you will get an error.  By using "Create or Replace", I know I will have the latest data in that file.
Message 12 of 14
(2,494 Views)
I learned something new, thanks.
Message 13 of 14
(2,472 Views)
Hello Bob,
There was indeed something fishy in my Write Binary VI that I didn´t detect before. It is now working as intended!
Also, your example introduced me to some new functions that I was completely unaware before, but that seem quite handy to deal with file paths. Thanks!
Message 14 of 14
(2,454 Views)
