Issue with Custom Needle Image Rotation on Speedometer Gauge
Hi everyone,
I am trying to customize a standard LabVIEW Speedometer/Gauge control by replacing the default needle with a custom image, but I'm running into a rotation logic issue.
The Problem:
When I import my custom image (originally 12x150 px) onto the needle part in the Control Editor, the needle moves along the gauge arc but stays vertically static—it doesn’t rotate to point at the numbers.
What I've Tried:
I followed the common advice of placing the needle on a transparent square canvas (300x300 px) with the base of the needle positioned at the exact center (150, 150) to create a pivot point.
I want the custom image to behave like a standard vector needle where the base stays fixed at the gauge center and the tip rotates to indicate the values.
Any advice or example .ctl files would be greatly appreciated!
Message 1 of 10
(1,621 Views)
Why not start with a Gauge control?  You can easily change the lower and upper limits, and make the lower and upper limits, say, 0 and 100 (mph).
Bob Schor
Message 2 of 10
(1,589 Views)
You can't do this directly, because LV doesn't know how to rotate your image. The original needle is a line-type PICC (a custom vector image format that LV uses internally) and that's the only thing that LV knows how to rotate in this context. You can customize the gauge and replace the needle with another line-type PICC, such as the arrow, but not with your custom image.
If you do want your own image, you can use a picture control on top of your gauge and use the picture control functions to rotate your image, but that comes with a few caveats:
  1. I believe the picture control still doesn't support alpha transparency for the images that it shows. It's possible to get an image of the background yourself and do the blending on a pixel by pixel basis, essentially redrawing the gauge from scratch. This will probably require you to hide the picture control at least once to get the background image. If you have other things there which are changing constantly, you might need to repeatedly defer updates, hide, get the image and undefer.
  2. You would need to account for the relevant transformations and rotations and calculating the scale so that your needle is shown correctly.
  3. The performance for it might not be great and it might look pixelated.
People have all kinds of work on customized gauges. I suggest you look around. It might also be possible to use a .NET or HTML control, where you might have more customization options
___________________
Try to take over the world!
Message 3 of 10
(1,546 Views)
Hi, Bob_Schor,
The main issue is to customize the needle for gauge control in which i am facing problem. So if you have any suggestion for this problem it will be helpful for me.
Message 4 of 10
(1,532 Views)
Hi Abhishek,
Do what tst suggested to you…
Once I had a similar problem and I ended up using a XYgraph:
  • I placed the image of a (car) speedometer as background image
  • I used a plot with a thick line as needle.
  • I adjusted the XY scales so the needle was moving in the correct positions.
(You can hide all the functionality inside a XControl…)
Message 5 of 10
(1,525 Views)
Hi tst,
Thank you for the suggestion. I have one more question: is it possible to create a customized line-type PICC for needle that I want ? I am relatively new to LabVIEW and still gaining experience, so my current knowledge is limited. I am learning primarily through hands-on project work.
Message 6 of 10
(1,513 Views)
Hi GerdW,
Thank you for your suggestion. If possible, could you please share the VI implementation of your idea using the XY Graph?
Message 7 of 10
(1,508 Views)
Hi tst,
Not really. The PICC format is LabVIEW proprietary. It is similar to the Macintosh PICT format but not the same, since NI had to create their own routines anyhow for non MacOS versions of LabVIEW. There is AFAIK no editor outside of NI that could create the necessary resource format and I found never enough motivation to try to reverse engineer such an archaic feature.
It is also quite unlikely that NI would even spend any effort to create new PICCs nowadays. The software routines to handle them are there, but they were developed 35 years ago at a time when the LabVIEW developers were fighting for virtually every byte that could be saved. That code is accordingly arcane, difficult to maintain and almost impossible to modify by modern software developers who are used to very different architectural and structural designs. The Custom Control Editor to manipulate these controls is quirky and has strange artefacts when dealing with such PICC (and other) resources.
And yes, LabVIEW also supports WMF and EMF formats which are the Windows equivalent of PICT. However WMF is highly limited and has many quirks that were interpreted differently by different software packages and even between different Windows versions. EMF was an attempt to standardize it and extend the format to allow for coordinates beyond 16 bit size but still had quite some quirks and there were only very few applications supporting the use of that format. The Windows GDI still supports it, but due to its rare use I would not be surprised if it has bitrotted since. I don't believe that LabVIEW tries to convert EMF to PICC in any way, so if you use EMF resources in your controls or frontpanel they usually end up as empty rectangles on non-Windows systems. And you have similar quirks in the Control Editor with EMF resources as you have with PICC or PICT resources when trying to manipulate them in any way.
Rolf Kalbermatter  My Blog
Message 8 of 10
(1,488 Views)
Hi tst,
You are such a wealth of knowledge. Never EVER leave this forum!
Bill
CLD
(Mid-Level minion.)
Message 9 of 10
(1,440 Views)
Hi everyone,
I wanted to follow up on this thread and share the complete solution, as I managed to get it working perfectly!
After a lot of trial and error with the native LabVIEW Control Editor (.ctl), I found that trying to bind asymmetrical custom images or complex, multi-layered visual requirements (like a dynamic target speed arc matching the needle color) directly to the native vector gauge is incredibly restrictive. The image stretching, lack of true dynamic canvas rotation handling, and front-panel flickering make native image-swapping impractical for high-end client requirements.
The Solution:
Instead of fighting the native Control Editor, I bypassed the legacy ActiveX system and built a custom UI control from scratch using C# (Windows Forms Control Library) via GDI+ vector graphics, and embedded it directly into LabVIEW using the native .NET Container.
This method completely avoids the Windows Registry (regasm), allows you to pass background images smoothly, draws custom-shaped needles natively with math, and lets you pass U32 colors straight from LabVIEW into the C# UI tracking engine.
Here is the blueprint and the C# code if anyone else is trying to do this:
1. The C# GDI+ Code (UserControl1.cs)
Create a standard .NET Framework (4.7.2 or 4.8) Windows Forms Control Library project in Visual Studio. Turn on double buffering to eliminate screen flicker, and used the exact painting layout matrix to handle the center pivot point alignment dynamically.
2. How to map it in LabVIEW (.NET Container)
  1. Build the solution in Visual Studio to generate the .dll.
  2. Go to the LabVIEW Front Panel, open the palette, and drop a .NET Container (Modern -> Containers).
  3. Right-click the container frame → Insert .NET Control..., browse directly to the compiled .dll file, and select UserControl1.
  4. Create a Property Node on the Block Diagram from the control reference terminal. Drag it down to expose: BackgroundPath, CurrentSpeed, TargetSpeed, NeedleColor, and TargetArcColor.
  5. Important Performance Optimization: Wire the BackgroundPath (using Current VI's Path and Build Path string nodes) outside of your loop so LabVIEW only triggers a disk-read stream once at boot.
  6. Place your CurrentSpeed and color properties inside a While Loop with a standard 30ms wait timer. You can wire LabVIEW's native Color Box controls directly into the color property nodes since they map flawlessly to the underlying integers!
This approach completely solves the off-center warping and pivot sliding issues typical of standard image customization methods inside LabVIEW. Hopefully, this helps anyone else working on high-performance custom industrial indicators or automotive simulation dashboards!
📌 DEVELOPER NOTE: Before compiling this code, make sure you launch Visual Studio by choosing "Run as Administrator". Also, please remember that once LabVIEW runs a VI containing a .NET container, it places an active system lock on the compiled .dll file. If you make changes to the C# code, you must completely close LabVIEW before clicking Rebuild in Visual Studio. If LabVIEW remains open, Visual Studio will throw an access/write error and refuse to build the project.
Message 10 of 10
(886 Views)
